For any Bosch Motronic / chip tuning experts, I have a question!
I understand that in the S4 the ECU is programmed to achieve a certain torque or load value, which it estimates based on the MAF signal. So when it gets cold enough out and the air is denser, the MAF signal is higher and the computer may cut boost slightly to not go above it's preset torque level. Bummer there. But what I'm wondering is, when you add say downpipes and exhaust, which will increase airflow through the engine, why wouldn't the airflow gain be defeated by the engine management when the MAF signal increases beyond the preset load value (just like when it is cold out) - i.e wouldn't the computer again cut boost,
and the power you can make is ultimately limited by this preset load/torque value? If not please explain!
stage 2+ i think really doens't benefit from more boost
although lower cylinder temps could let you run a litle more boost or timing
*I* think that the more efficient combustion makes up the difference..not so much the tuning
Lets say it does increase airflow, wouldn't the MAP only pump enough fuel up to the max preset power level, so anymore flow is usless right?
You going to be in that drive this weekend?
I think that the idea the EVERY CAR MAKER
builds ****ty or "compromised" intakes or exhaust systems is
OLD SCHOOL or "old wives tales"
it's not ALWAYS the case
