Any comments on these fault codes?
edit delete
VAG-COM Version: Release 303.1
Control Module Part Number: 8D0 907 551 B
Component and/or Version: 2.7l V6/5VT G 0003
Software Coding: 06651
Work Shop Code: WSC 06325
5 Faults Found:
17819 - Secondary Air Injection System: Bank 2: Insufficient Flow
P1411 - 35-10 - - - Intermittent
17883 - EVAP Leak Detection Pump: No Signal
P1475 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17535 - Fuel Trim: Bank 1 (Mult): System too Rich
P1127 - 35-00 - -
17537 - Fuel Trim: Bank 2 (Mult): System too Rich
P1129 - 35-00 - -
5 Faults Found:
P1127 - 35-00 - -
P1129 - 35-00 - -
unscrew the maf sensor, spray it down in there real well on the metal tab, brush it, and than go out for a drive and re-vag it and see what happens.
good luck.
Ray 90G60 Tornado Red
00 S4 silver/onyx
good luck.
00 S4 silver/onyx
rktskicar
08-26-2008 12:37 PM
NJ1.8
07-01-2008 05:38 PM
