Any ideas on a misfire code in cylinder 6? The car shudders and
throws a blinking CEL around 8-10 lbs of boost in any gear. Just reinstalled the engine after K04 plus other goodies. Still running my APR Stage 2+ software. Recently replaced EGTs and O2s.
Also, I have swapped out the coilpack for # 6 with another cylinder (still shudders & CEL); changed the plug in cylinder 6 (still shudders & CEL); and swapped back to my stock ECU (still shudders & CEL.
Here's my VAGCOM results:
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16690 - Cylinder 6: Misfire Detected
P0306 - 35-10 - - - Intermittent
Any ideas what may cause the misfire?
i had the SAME thing but cylinder 4 i think. my info inside.....
It ended up being a MEGA boost leak right off the turbo,
One of my banjo bolt came loose and needed to have a new lock washer put on. do a pressure test,
