Any plans to for a catch can install tech article covering both the 2000/2001
as well as 2001.5+ install. Detailing the piping differences, which cans fit best (to date) etc.
in opinion on what's the best method. Some of the pics made my eyes go cross ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I will look through it again, a diagram would be nice.
i put in a load of extra effort cause i wanted that brittle plastic POS spider out of the car entirely.
I cut the PCV from the rest of the spider. Using 5/8" ID tubing I installed a small air compressor filter between the spider and PCV. I also deleted the F-hose. Basically you connect the EVAP line to the manifold port and plug the other line that went to the spider. If you need pics, check out the post from snowtrooper.<ul><li><a href="https://forums.audiworld.com/s4/msgs/2284001.phtml">https://forums.audiworld.com/s4/msgs/2284001.phtml</a</li></ul>
blAck6 (desairs)
9
05-27-2008 09:48 AM
jaytopia
10-03-2006 04:07 PM
brrman
09-15-2004 07:28 PM
pinkertonfloyd
01-24-2003 05:40 AM
