any possible way to leave N75 in WITH electronic boost controller?
I would like to leave the N75 valve in as a factory safety feature, rather than eliminate it. Pretty much take away its control, but still able to set a code if a problem come up. Also to switch off the EBC, so it can return to the n75 control.
over charge pressure. If it feels that its necessary for you to be in limp mode, it will limit you to ~20% throttle which will not allow you to build any more than ~0.4 bar of boost.
-Dave Pramanik
-Dave Pramanik
Its just not going to do it due to an overboost (which is the whole point of the TCD).
If you've got a TCD, then the N75 isn't going to do anything with limp mode from the overboost because the ECU will never see an overboost.
-Dave Pramanik
-Dave Pramanik
Kingttr
09-16-2008 12:46 PM
PhunkFX
05-06-2007 07:30 PM
ski ya later
05-12-2006 12:08 PM
mpwolf
19
08-03-2003 07:12 PM
