Any reason not to run the High Capacity Oil Filter Vast carries?
Old 09-15-2006, 10:13 AM
nobodeuno's Avatar
Default Any reason not to run the High Capacity Oil Filter Vast carries?
Been ordering from ECS but figured I'd try vast this time around and noticed they only had High Capacity Oil Filter...tried a few searches and it looks like its fine just runs a bit extra oil...which is fine by me!
Probably a silly questions but any reason not to run the High Capacity Oil Filter?
Old 09-15-2006, 10:15 AM
Marx's Avatar
I run them. No problems here...
Old 09-15-2006, 10:16 AM
Member
bitjockey (bum)'s Avatar
It can only help.
Old 09-15-2006, 10:38 AM
Dubs's Avatar
Why run it in the first place?....
Old 09-15-2006, 11:10 AM
Andrew C.'s Avatar
Default the stock barely fits (length-wise) w/ an OCK sandwich plate. don't know if the VAST is longer or
wider, but if it's longer, you may not be able to use it w/ OCK. if it's the same length, but wider, it may work.
i didn't take the chance and just stuck w/ the OEM ones.
Old 09-15-2006, 11:49 AM
erik9108's Avatar
2nd. There's no way I could run a longer oil filter with my oil cooler. Mann stock filters for me.
Old 09-15-2006, 12:09 PM
Cerveza's Avatar
Default I have them. Tight fit, but they work fine.
The reason I use maybe kind of stupid, but the way I look at it, they kind of act as a poor mans oil cooler. It introduces more oil into the total equation, thus spreading around more oil to handle the heat. I would think that that would cause the oil to be more resistant to heat overall. I don't know if it is harder on other parts because of the added "strain" of pushing more oil around, but I live in Houston and it is hot most of the time. My turbos take a beating so if I can spread the heat around more, it makes sense to me. I have noticed my temps a little lower than with regular.
WickedSmaht
Audi A3 / S3 / RS 3 MKII
08-15-2015 09:44 AM
mattarios2
08-21-2005 05:35 PM
AudiSport4000
04-04-2005 01:59 PM
TTapsale
07-15-2002 03:23 PM
sidespar
24
09-18-2001 06:12 PM
Quick Reply: Any reason not to run the High Capacity Oil Filter Vast carries?
