Any reason why my car has problems sometimes getting into 1st gear? I havn't had any slippage ...
just sometimes sitting at a light, 1st is locked out. The same goes for reverse (moreso).
Do I need my SS adjusted?
TIA from a n00b!
TIA from a n00b!
fluid might help too.
i'm just somewhat accepting of it and sometimes launch from second when i can't get the car into first fast enough (when rolling).
i also find if i put the car into second (just engage, no need to let out clutch), then it'll go into R easier. this helped on my 86 GTi as well. it's habit now.
but in this car sometimes it just plain won't go into R unless the wheels move a bit.
shift into second, before shifting into first (if it gets locked up at a light.) By shifting into 2nd, the synchros will budget a bit and you'll be able to get into 1st.
I had no reverse and I had to fight with the shifter to get it into first. Try adjusting you SS first.
your SS. I had the same problem and tweaked with the SS and all was fine. I think it was 7 degrees back and 3 degrees to the left? The other bolt (using your allen wrench of course) should be adjusted towards the middle) New tranny fluid wouldn't hurt either.
youngspeed
05-31-2005 06:34 AM
VandyS4
01-18-2005 05:30 PM
faiz_twinzdaddy
Canadian Discussion
01-19-2004 06:20 AM
J4SON
08-09-2002 10:28 PM
