Anybody else's car REAL sensitive to to longitudinally-uneven pavement under hard braking?...
You know, wide grooves running the same way as the road, like where a lot of heavy trucks have been running?
My old GTI VR6 was rock-solid under the same circumstances. My S4 feels like it's diving for the other lane somtimes.
I've chalked it up to wider 17-inch versus 15-inch wheels. Will stiffer suspension help? How about other tires?
Yeah mine does it too, I just assume its a natural behavior of the suspension in there.
Its disconcerting when you're not expecting it, but you get used to it.
… to the squirmy tread blocks, measly 205 section with big circumferential groove down the middle and overly enthusiastic piloting on may part. 225/45ZR17 S-02 PPs are on now and I haven't had the problem on the same piece of road.<p>2000 Nogaro/Silver - S4
UUC Shifter
UUC Exh
S-02 PP
UUC Shifter
UUC Exh
S-02 PP
One way to minimize that if it really bothers you is to toe the front end IN a little more. That improves stability at the expense of numbing turn-in.
A common autocross setup is to increase toe-out to make the car a little more "darty" which, depending on the car, may be desirable in an autocross.
I had 2953's problem, but I have since switched to summer set-up,MM Spiders w/225/45/17 Yoko AVS Sports.Now the car tramlines under all conditions-not just braking.Maybe reducing the unsprung weight(via the lighter wheels)has caused this problem.I may try a fix by increasing toe-in.2953,or anyone, have you tried this?
Snapper09
03-12-2002 10:01 PM
2953
07-04-2000 09:17 PM
Kevin Caldwell
Wheels & Tires Discussion
12-12-1999 07:36 PM
