Anybody have wiring diagram for airbag module harness?
I am trying to isolate the switched power wire for the airbag module harness. Can anyone help identify the switched power wire for the airbag module?
I know what pin the switched power is on the module harness but because its a 90 degree plastic harness with a solid backing and small opening I cannot visually trace the pin to the switched power wire.
WHY I NEED TO IDENTIFY SWITCHED POWER: I'm going to run a jumper from the radio memory wire (constant 12V) to the switched power wire on the airbag module to eliminate 65535 memory fault found errors on the airbag module due to cold weather. Providing a small amount of constant current to the module prevents memory faults due to cold temperatures.
jfischetti
05-27-2004 06:43 AM
