Anyone in CT have a Cam Tensioner Compression tool (#3366) that I could borrow for Monday?
AudiWorld Expert
Unfortunately, I had overlooked the need for this tool to move the cams from one head to another. Anyone local have it that I can borrow?
<img src="http://www.samstagsales.com/images/vw_matra_3366.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/cam_replace77.jpg">
Thanks!
Thanks!
-2.5" in length and 1/2-3/4" wide-ish. i just tightened the bolt with a nut under the scrap and the bolt head on the other side to hold it in place (just loosely tightened). The bolt hole is a common size and you just need to rig something to push it down as you screw the bolt in.
This might not make much sense reading it but it was a very easy tool to make. If i find it, i'll snap a pic of it and post it up.
dragon-ryder
12v V6 Discussion
12
07-18-2005 02:01 PM
PismoJeff
01-04-2005 04:12 AM
