Anyone else suffer loosening wheel wheel bolts ???
A week ago I discovered a loose wheel. I retightened the lug nuts to 90 lb-ft. This morning I noticed a slight vibration. It got worse in the afternoon. I stopped at a garage and discovered that I again had loose wheel bolts on the same wheel.
Anyone have this same problem?
At least I am able to spot the problem pretty quickly and re-tighten before the wheel comes off. But I still worry that a wheel might crack.
Stephen
Stephen
your bolts may not be long enough. i had this problem with the bolts that Edge Racing
sent me with my Flik Lex's. maybe 25mm threads and engaged only about 4 full turns. i changed to 29mm (iirc) and the loosening problem went away.
this assumes aftermarket wheels and lug bolts and not the stock set-up.
typo -> bolt's seat match the wheels
Yes...
But what I took off was the aftermarket ECS rotors and I put back on the original stock rotors that came off.
Before I put them back on I used a wire wheel on a drill to remove all of the loose rust.
Stephen
Stephen
Stock brakes...
As I said, I could feel a very slight vibration. They got worse slowly. I don't think most would have even noticed it.
The previous time was much worse. I limped home in the car (thinking a CV-joint have gone). Then they were really loose.
Stephen
Stephen
