Anyone familiar with DTC 18014 Rough Road Spec Engine Torque ABS-ECU Electrical Malfunction
#14
you'll see it just to the driver's side of center. It's about the same size as the ECU if you've ever seen one. Has a thick wiring harness connected to it - I think the harness holds ~58 wires, IIRC.
#15
So that's where it is. Now I'm suspecting that it might be my wiring even more now. I remove my back seat at least once a month for autox and track events, and that has to put a decent amount of stress on all the wires running around there.
Thanks again =)
Thanks again =)
#18
I'm not immune to being wrong, but I think the control unit you're referring to under the back seat is for ESP? It also operates hand-in-hand with the ABS, so I could see where the relationship could be viewed to call it the ABS control module.
Drew, Chris, we'll get to the bottom of this..... ;-)
#19
one said ESP on it and I'm 99.9999% sure the other one was the ABS controller -
Bentley was giving me things to check in the wiring harness for what they were calling the ABS controller - the pins matched up and I was guided to my problem.....
I think we might be talking about 2 different things.
