anyone guess the pressure difference between compressor and intake manifold (at WOT/redline)?
Old 07-29-2005, 11:39 AM
davenew's Avatar
Default anyone guess the pressure difference between compressor and intake manifold (at WOT/redline)?
I'm thinking about buying a differential pressure gauge to see what kind of pressure loss we have, just for the hell of it. I seriously doubt it's much over 2-3 psig. Having a new AVC-R and vastperf. TCD in the mail has me thinking about turbos and boost, etc.
Once you know the max normal pressure difference, I think you could install a pressure switch to detect boost leaks. Does that sound right? thanks
Old 07-29-2005, 11:43 AM
Mike2kS4's Avatar
On stock intercoolers and K16 I was getting 4-5# of pressure drop. Haven't measured since.
Old 07-29-2005, 11:49 AM
Mike2kS4's Avatar
Default If you're running your car hard enough I think a leak would be pretty evident...
But if you want to geek it up a notch, feel free
Old 07-29-2005, 11:53 AM
Funkweasel's Avatar
Geeking it up would be to install an electric diff. gauge and wire up a warning light.
Old 07-29-2005, 11:57 AM
Mike2kS4's Avatar
Default That's what I think he was going to do next ;)
Read the bottom of his post! PITA!!!!
Old 07-29-2005, 11:58 AM
Mike2kS4's Avatar
I'm guessing the norm on K04 with upgraded IC's should be < 2#
Old 07-29-2005, 11:59 AM
Funkweasel's Avatar
Default If I didn't have such a massive case of ADD, I'd have seen that. Doh! But yeah
one of the pressure switches you can buy from Napa would work, just plumb the "reference" side to manifold pressure and the pressure side to the compressor and tadow. $15 warning light.
Old 07-29-2005, 12:00 PM
Funkweasel's Avatar
Default Depends on the tuning. With AWE's tests they saw over a psi on just
the ICs. Do you think that the total system drop is <1psi?
Old 07-29-2005, 12:01 PM
davenew's Avatar
Default pot calling the kettle black?:)
You gotta keep doing something to the car after the major mod money starts running low
Actually, I have a very steady 2 psi boost leak right now. I lemmied the timing up 5.25 deg and wondered why it took it so well.. It liked the advanced timing because the boost wasn't where it should be.
I did a pressure test and didn't hear the slightest leak. Someone mentioned the N75 valve as a possible culprit. I just spent $100 to replace it a few months ago, as a preventative measure. I'll throw the old one back in and see what happens.
Regardless, it would be nice to have a light come on when the pressure difference is 1psi or so more than it should be. It wouldn't help with a bad N75 but you know what I'm talking about.
Old 07-29-2005, 12:02 PM
davenew's Avatar
dang, did you hack my computer and see what I was typing?
Quick Reply: anyone guess the pressure difference between compressor and intake manifold (at WOT/redline)?
