anyone have the how-tos on replacing a coolant reservoir? thx
after you get some of the coolant out with a turkey baster,
then, undo the 3 phillips screws and pull the container up
then, take a flathead screwdriver and stick it in the coolant level connnector tab and gently pry down until you hear a small click, and slip the connector out
squeeze the spring clamp for the outlet hose and pull it down the hose a bit, then raise it up so you don't leak coolant. and then just slip the hose off.
then put your new bottle in! make sure it's clean...might want to flush it with a little water
javanator
07-28-2008 09:08 AM
quattro-sport97
12-11-2005 05:00 PM
Onemax
09-13-2003 08:36 AM
