Anyone here using the larger oil filter for the 1.8T on their 2.7T?
didn't fit w/ the OCK sandwich plate i have.
Press relief valve comes into play at cold start and at WOT/high rpms - oil will bypass the filter.
Might not cause any significant extra wear on engine, but ideally you want the oil to actually get filtered as much of the time as possible. That is why brands like Fram suck so bad - very low bypass pressure and the oil ends up bypassing (not getting filtered) majority of the time.
If you oil filter's media gets clogged and it bypasses, you are already in big trouble...
