ANyone install Bosch 044 and have problems starting right away?
Im in CA heat, not cold weather, but if I leave the car for more than 2 hours it will lose pressure (im guessing) and take up to 8 seconds of cranking to get her started..
If its less than an hour then she starts up right away..
Does this indicate I have a leak in perhaps one of those fuel lines? Im gonna check with it running...
They tell me this pump has the check valve on top..
well, any ideas appreciated, thanks guys.
I got it from 034 , so I double checked too and they said it has the check valve.. the nut thing on top is app where it is I guess
Dap why does it lose pressure? Do I need more than one check valve?<ul><li><a href="https://forums.audiworld.com/s4/msgs/2819250.phtml">https://forums.audiworld.com/s4/msgs/2819250.phtml</a</li></ul>
Check for leaks elsewhere in the fuel system where pressure could be lost.
If it started right after the pump install, I'd pull out the pump and check over the lines and connection points closely.
