Anyone know what to make of this log?
<center><img src="http://pictureposter.audiworld.com/291/actreqk04.jpg"></center><p>
This is a log of a steady cruise at about 18% throttle up a slight incline at 4000 rpm in 4th gear.
Pressure tested, ECU chips swapped, N75's swapped, DV's swapped.
All known good parts have been installed on this car for testing.
The car makes 1 bar or more of boost at all times, other than at idle. Trying to hold a steady speed is a nightmare as boost surges continuously between 10-25 psi.
NO CODES! LOL!
NO CODES! LOL!
So would you say that looks like the wastegate is staying shut for some reason and the ECU is
probably cycling the N249 to dump boost?
I've thought about dumping the n249, but I haven't had problems with it yet.
could be a stuck wastegate, but the car runs ok with a stock chip
so that would lead me to believe the programming is kinda wacky.<ul><li><a href="https://forums.audiworld.com/a4/msgs/1963125.phtml">https://forums.audiworld.com/a4/msgs/1963125.phtml</a</li></ul>
I'm just an outsider
I'm told all the vac lines to and from turbo/N75 were replaced and are good. I agree checking the wastegate is a good idea. Any other boost controlling device would be a good idea. I've suggested running the car with no boost control other than the wastegate spring tension to see what happens. I know my turbo will only hit 8 psi and it's supposed to. Not sure about an A4 K04.
German Driver
19
04-25-2005 09:37 PM
Alias Unknown
Canadian Discussion
10
07-07-2004 02:06 PM
got_root?
08-04-2001 01:01 AM
