Anyone know where I can get silver paint to match Avus rims?
its easy to find on the internet for about $16. IF you have a wheel scuff search for NASA Racers wheel scuff repair and follow the instructions. It works!
I wanna paint my calipers to match my rims. I already painted them silver with Folia-Tec caliper paint, but it doesn't match well. What do you think?
Home > Paints & Adhesives > Wurth German Alloy Silver Wheel Lacquer
Click for detailed view.
Wurth German Alloy Silver Wheel Lacquer is a fast-drying lacquer that matches the standard allow wheel paint use by Porsche, BMW, Mercedes, VW, Audi and most other European OEMs. Wurth German Alloy Silver Wheel Lacquer can be effectively used for spot repairs or full wheel restoration.
The German design nozzle produces a fine, even spray that is easy to control and produces a near-factory finish. Wurth German Alloy Silver Wheel Lacquer dries quickly and is chip resistant. Use several very light coats and allow 30 minutes drying time between coats. The silver color coat will have a textured look and feel that provides a three dimensional effect when properly finished with a clear topcoat (use two coats of Wurth High Gloss Clear Lacquer as the final topcoat).
One can of Wurth German Alloy Silver Wheel Paint is enough product to coat two complete wheels. For the best results, use at temperatures between 70 and 90 degrees Fahrenheit.
400 ml aerosol spray. Ground shipment only.
NOTICE: THIS PRODUCT HAS BEEN ON BACK ORDER SINCE SEPTEMBER, 2003 DUE TO A MANUFACTURING PROBLEM. WE GAVE UP ON TRYING TO GUESS WHEN MORE WOULD BE AVAILABLE FROM WURTH. THE SAME COMPANY THAT MAKES THE PAINT FOR WURTH MAKES IT FOR EINSZETT. IT IS THE EXACT SAME PAINT.
