anyone run a 2 step?
#11
<img src="http://img.photobucket.com/albums/v355/RotaryWeapon/Illtakethree.jpg">
This guy might need a little help getting going.
(Thanks to Verrukt for the post <a href="https://forums.audiworld.com/s4/msgs/1947207.phtml">here...</a>)
#12
the diameter of that compressor wheel is about 18".
<img src="http://i2.photobucket.com/albums/y49/BuehnEng/p1010150.jpg" alt="Image hosted by Photobucket.com">
#19
...with a boost shut off (at least I think you would).
So rally cars and JGTC cars run anti-lag systems to maintain boost when braking/downshifting into turns so that when they go for the gas, they get all the motor has and don't have to wait for boost to build.
You're essentially running valve overlap and pushing fuel into the exhaust manifold (unburnt) to flame off on the manifold and keep the turbine spinning.
For the 1/4 mile, you're not really downshifting and braking (at least, not needing full boost when you're doing it). So you could run a nitrous shot that shuts off once you make full boost to compensate for the lag (probably can find more on this from Supra owners).
This is all my rambling, I'm no drag racer, nor do I build anti-lag motors for WRC or JGTC...
#20
The thing that holds the transmission between reverse and 1st gear (in an auto) is a "transbrake". The thing that keeps a 2WD car from moving while doing a burnout is called a "line-lock".
