Anyone run thinner oil in New England winter?
I like the oil heater idea a few posts down. But I was thinking for the type of use my car gets in winter, a thin oil would do nothing but help. The S gets no long distance use from Nov to Mar, only a 25 min off highway commute. I generally don't even swap APR programs out of stock mode.
0W40 is really the best of both worlds as it pours like a 0 weight oil when cold but protects the engine (and turbos) like a 40 weight oil (or so the marketing would have you believe).
Mobil lists the pour point of their 0W40 at -54°C (-65°F)... I HIGHLY doubt you'll see any temps that low in NY!
-Dave Pramanik
-Dave Pramanik
FWIW... and no I won't get into an Oil discussion.
Synergyn:
SAE Grade 0w - 20 Weight Engine Oil
Viscosity @ 40 Degrees C 48.2
Viscosity @ 100 Degrees C 8.8
Viscosity Index 165
API Gravity 31.7
Specific Gravity 0.867
Flash Point, Degrees F 410 Degrees F
Pour Point, Degrees F -65 Degrees F<ul><li><a href="http://www.synergynracing.com/products/sae0w20.html">http://www.synergynracing.com/products/sae0w20.html</a></li></ul>
Synergyn:
Viscosity Index 165
API Gravity 31.7
the 40 gives a better viscosity at higher temp ( normal runing temp of the engine) pour point for 0-20 is -57 degrees and for 0-40 is -54 degrees (3 degrees is nothing).
just another thought
