Anyone used AWE's stage 2 clutch on their S4?
#15
flowing more exhaust, sooner...so I think it's possible. Don't know the actual physics behind it.
#16
and a much stronger than stock PP will be nicer and stronger overall than a standard RS4 setup. We'll see! It has to be smoother with a more stock like engagement.
#18
but it would definitely affect how quickly the engine revs. The actual physics are a bit complicated, but when you remove weight from a rotating assembly, it has a greater effect than simply removing dead weight. In addition, since the weight in this case is removed before the transmission, it will have a significant effect in lower gears, particularly 1st + 2nd.
