anyone using FK spacers?
I'm looking at getting either 10mm or 15mm for my stock Avus rims. Ideally I'd go with MTM but at $270 for a set of 4, that seems kind of expensive for spacers. FK and H&R are cheaper. I STFA and saw quite a few negative comments about the H&R's. I don't know if this is only because they're the most popular or if they actually are problematic. Achtuning has the FK spacers for about the same price as H&R (~$200 for a set of 4) . Anyone have any experience with these FK spacers?
Or should I stop being stingy and drop the extra $75 or so and go with MTM?
rishiS4
rishiS4
do u know if they were Type A, B, or B+
Seems like with Type A you just use longer bolts to bolt on the spacer and the wheel.
But Type B and B+ you actually use the supplied bolts to bolt the spacer to the hub and then use the regular bolts to bolt the wheel to the spacer. Seems kinda strange to use 2 sets of bolts.
rishiS4
rishiS4
lx4life
03-22-2018 05:35 PM
Hartmann/Achtuning
10-14-2005 06:51 AM
Fluffhead
01-28-2003 09:07 AM
