Is anyone using the STaSIS brake duct kit?
#23
controlled tests with and without the shrouds to see just how much affect they have.
#25
on a VW belly pan, but decided to wait until I have some more space where the RS4 intercoolers are mounted. ; )! The intercooler inlets on the RS4 bumper will be perfect for routing air to the brakes. BTW...the high temp hose is pricey$.
#29
make a "reverse" duct on the back of the intercooler that would neck down into a 2.5 or 3 inch hose... question is, would there be enough pressure to support adequate cooling of the brakes? Maybe a combination of lower NACA ducts and a modified rear intercooler duct? Use a simple 2 into 1 conduit which would feed the spindle-mount... All of these parts are very commonly found in circle track catalogs and stores.
We shall see... I won't have time to play with this until late summer.
#30
They just need to pull off the inlet covers, I think. He may have been assuming that it was equally easy in an S4, which it's not, unfortunately.
