anything special with 20k service?
Re: anything special with 20k service?
Here you go. You can actually register on audiusa.com under My Audi and view the maintenance schedules.
Also, thanks for sending me the zip file.
Eric
Engine Oil - Change the oil.
Engine Oil Filter - Replace the oil filter.
Engine - Check for leaks.
Cooling System - Check the coolant level. Add coolant if necessary.
Exhaust System - Check for damage and leaks.
Engine, On-board Diagnostic - Check diagnostic trouble code memory. Purge if necessary.
Doors - Lubricate door hinge mechanism.
Battery - Check electrolyte level. Add if necessary.
Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
Automatic Shift Lock (ASL) - Check operation, including park/neutral position switch (where applicable).
Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
Tires and Spare Wheel - Check for wear and damage. Check the pressure.
Service Reminder Indicator Display - Reset the display.
Brake System - Check for damage and leaks. Check thickness of pads and brake fluid level.
Drive Shafts - Check the boots.
Lights - Check the lights.
Front Axle - Check dust seals on ball joints and tie rod ends. Check the tie rods.
Automatic Transmission - Check for leaks.
Manual Transmission - Check for leaks.
Manual Transmission Final Drive - Check oil level. Add oil if necessary.
Dust and Pollen Filter - Replace filter.
Headlights - Inspect headlights. Adjust if necessary.
Sliding Roof - Clean guide rails and lubricate with grease spray.
Eric
mrvirgilg
01-27-2005 12:45 PM
