It appears that only Stasis tracksports gives you spring options
Streetsports doesn't. I don't want to pay 2 grand for tracksports-so where can I purchase custom springs. FWIW-streetsport rate is 370-f and 400-r (from what I recalled). Eibachs are linear and 360-f and 303-r.
then how are you going to use a flat race spring with the OEM rubber spring mounts?
You can't.
And if you go custom springs, what lengths and rates?
And since you are using the Street Sport damper and valving, how do you know that more spring rate will even work well with the valving in that kit?
The Track Sport kit solves all those issues for you, and gives you a wide range of spring options. All the custom hardware is included, has been tested. The combination works.
You can't.
Tomasz@Startup
68
08-20-2006 08:23 PM
tazcashmoney
08-24-2005 09:47 AM
perfution
14
06-29-2004 11:54 AM
bhvrdr
54
05-05-2004 07:16 PM
