APR center vent boost gauge wiring question?
I just realized that there is no connection for the light. Can I just run a wire from one post to a switched power source and the other post to a ground or is this more complicated?
Anyone have a clean solution?
Thanks.
Thanks.
gauge. What kidn of gauge do they use. Sounds like you might be confused with the mounting hardware and where the light connections are....I'm a bit confused on what you are asking.
and have access to the bulb. That is how you would change the bulb and how you would put the colored cover over the bulb. You can either solder wires to the connectors or get the apporpriate connectors that fit those flat pins and crimp them onto the wires. Again, I didn't bother running wires all the way to the terminals, I just spliced the wires that are already there. Just simple splce taps from a hardware store. Splice the red wires and connect it to a terminal on teh gauge, and do the same with the black wire.
