APR Chip'rs - Question about the Fault Codes Erase. more...
Monday I'm taking my car into dealer. Going to swap with stock ECU.
Someone recommend I have codes cleared. Can I do this with APR's FCE or do I need a Vag Tool?
TIA.
TIA.
...so I'd recommend finding someone with a VAG tool to clear the power-loss DTC for you. And make sure you drive the car enough to reset the readiness codes.
1. (Preferable) Find someone who has a Vag-tool to erase the low voltage code and/or by the Vag-tool, you're going to be needing it.
2. Drive the car for 30 miles or so. I'm not sure anyone know how long it takes for the code to be self erased. After a 45 min drive, I still had the code in memory. So, be careful if you take that route.
...where x is some number between 10 and 30, from what I've heard. Just starting the car and driving it will not clear the power-loss DTC, it will however start to reset the readiness codes.
box_of_partS4
03-21-2005 10:23 AM
How long after resetting ECU (clearing codes) do you have to drive before you clear the reset codes?
Yeehaaa!!!
01-07-2003 03:08 PM
Ghant TMK
01-02-2003 06:00 PM
ch11
12-26-2002 10:41 AM
