APR ECUx Issues --> Anyone else having these errors come up?
just bought ECUx and tried to at least read codes and im getting these issues:
run-time error '713':
class not registered.
you need the following file to be installed on your machine. MSSTDFMT.DLL.
as soon as i hit okay it kills the program. also when i go to actions-->settings i get the same error and it kills the program.
and finally, when i go to action-->check DTC codes-->load the VAG120 file--> i get 'ECU Initialization Failed'
what the heck is going on? for reference im using a USB VAG cable and the VAG works just fine with reading codes. i will send APR an email and also post on AW to see if anyone else is having issues with these errors...
your specific case. Bottom line is that the VAG cable can work for ECUx and VAG-COM (and Lemmi).
damn, oh well. sent an email to APR and i will ring them tomorrow morning too.
was curious to know if anyone else had these errors here.
now, when i try to read my codes, it seems like its hung up again.
i adjusted my settings to read from the USB. after i hit ctl alt del to kill the hung up'ness i get this error:
error communicating with ECU: result not received
this is again after i select VAG120.
EdyJun
13
06-06-2006 08:31 AM
PSmalls::DoggieStyle
18
07-01-2005 05:13 AM
-M3=Lunch-
23
03-04-2005 05:25 AM
sj audi
Performance and Tuning
08-19-2004 03:23 PM
LI-S4
NY / NJ / CT Discussion
07-22-2004 08:14 AM
