APR Stg3 Tbox and Mbox run the same. Period. R1eater's car must be the oddball
Old 07-30-2003, 12:23 PM
  #11
AudiWorld Expert
Mark P's Avatar
Default That's fine - my point then is that they'd probably run the same on the T-program...
regardless if my car is fast, normal, or slow, the two programs run the same, and thus I'd expect them to run the same on anyone else's car as well.
I recall someone else posting that they tested both M & T boxes, and their results showed that they were the same also.
Old 07-30-2003, 12:24 PM
  #12
Agent Orange's Avatar
I ran 114 without RS4 Ic's or water injection for what it's worth
  #13
AudiWorld Expert
Mark P's Avatar
IC's, etc, to come in the future - we'll see what differences each make.
Old 07-30-2003, 12:26 PM
  #14
Default but that doesn't explain why these two cars are running so fast on pump gas program
they even dyno'd the cars and are way more powerful then anyone we've seen dyno an apr 93 program
  #15
AudiWorld Expert
Mark P's Avatar
RS4 plumbing on the airbox and after is larger than S4, so AWE S-Flo won't mate up
Old 07-30-2003, 01:43 PM
  #16
Junior Member
RichP's Avatar
Default Yeah but now that you have that wing you'll probably trap at 111mph
seriously though check out this link from Hoppen's site regarding RS4 IC's:
"Additional Upgrades
The addition of RS4 Intercoolers not only help keep the Turbos cooler, they
will also give you an additional 20HP, when combined with our 380HP kit
you will have 400HP! Specially modified by MTM to bolt-on perfectly!
Installation kit includes all needed hoses, pipes and hardware.
RS4 Intercoolers $1180
RS4 Intercooler Installation kit $531"<ul><li><a href="http://www.hoppenmotorsport.com/stage4.htm">http://www.hoppenmotorsport.com/stage4.htm</a</li></ul>
Old 07-30-2003, 01:52 PM
  #17
Senior Member
Prodigy's Avatar
Default hmm well you can always have a muffler shop bend you up a piece of pipe
if anything go with a drop in filter
I have an ITG OEM Style drop in for sale and cut the hole in the bottom, I had some decent flow numbers with that.
Old 07-30-2003, 03:46 PM
  #18
The R's Avatar
Default Well, both cars are M-box. Maybe that software works IDEAL with the components on an M-box. Plus,
Mark doesn't have RS4 ICs. We all know the short comings of our stock ICs.
Old 07-30-2003, 07:33 PM
  #19
Member
bioman's Avatar
Default Regarding RS4 ICs
Are you having as much trouble get your hands on a set as I am?
Old 07-31-2003, 03:37 AM
  #20
AudiWorld Expert
Mark P's Avatar
Default I'm waiting for AWE's to come out...hopefully that will be soon...
Are you going to the NE Event this weekend? If so, let's chat - I may have another source for the RS4 IC's
Quick Reply: APR Stg3 Tbox and Mbox run the same. Period. R1eater's car must be the oddball
