ASP K04 FATS inside 93 and 100 oct,,,
#11
ill eventually go with hybrids, prob RS6 wheels with all the goodies. Im no longer having boost creep issues so im seeing a friendlyer 21-22psi at redline.
#13
I posted my previous software log of 003 vs jwolf's<ul><li><a href="https://forums.audiworld.com/s4/msgs/2465546.phtml">https://forums.audiworld.com/s4/msgs/2465546.phtml</a</li></ul>
#16
not daily driving of course.....i dont have that kina cashola to blow on racegas. Pump setting will prob be 21.5 psi spike, taper to 20 at redline
#17
<center><img src="http://s4wiki.com/images/4/47/K04-0025.jpg"></center><p>its a flow limit thing.
again, look at the map. the top boundary of the map is overspin.
21 psi is approximately PR 2.6 on the y axis. where that overspin line drops at .14 on the x axis corresponds to about 360 g/sec, which is about 420 bhp.
#19
say in my case, I usually see 257~260g/s on 85mm maf running 22spike taper to 19.5~20psi by redline, am i off the effeciency range?
#20
2 psi for the IC and post-turbo piping, and 1 psi for the air filter and pre-compressor piping. That works out to a PR of 2.75 if my calculation is correct: (21+2+14.7) / (14.7-1) = 2.75
