AWE S-Flo owners - Just upgraded my filter to an AEM dryflow (#21-203DK) -->
#13
to reduce G/S numbers if you are seeing really high G/S.
I am not a fan of filters you have to oil. But ITG makes a great filter and will not calapse.
#17
Their reason for designing that retarded MAF was to mate with a stock airbox. Most, if not all, of the collapses have occured with AWE stage 3 cars. If you STFA, you will see Todd/Mike saying it's a bad idea to use the S-flo for that exact reason.
<a href="https://forums.audiworld.com/s4/msgs/2063664.phtml">Funk-dafied</a>
#18
air filter.
Maybe I'm wrong ? AWE later required a hole to be drilled in the stock airbox ala Darin to provide more air.
#19
it simply can't handle the airflow. That filter is only rated for something like 250-300 hp. so it creates vacuum in the intake, and the accordian hose collapes, not the air filter itself. The real question is why AWE ever use an S-flo. If AWE is going to sell a "high performance intake, it ought to be better than that, and compatible with higher hp setups. My 2 cents, learned the hard way.
