AWE Stage 3 with Buehn K03/16 - 4.81 FATS time
Old 07-06-2005, 07:04 PM
NoahD's Avatar
Default AWE Stage 3 with Buehn K03/16 - 4.81 FATS time
nothing fantastic, clearly, but it was on a slight uphill grade. It's tough to find something flat and open around Boston.
Boost is peaking at 2350 absolute (i.e. 1.35 bar boost) pretty constant from 5000 to 6500 rpm. It looks like the K03/16 is dropping off a LITTLE in actual boost (without requested boost dropping) by maybe 0.08 bar at the upper range of that, but that doesn't seem bad... the hybrid seems to be flowing as well as the AWE software expects.
Any suggestions for other things I should log? I'm pretty new to some of this, so not sure what other measuring blocks might be interesting. Cleaning my MAF sensor in alcohol cured my lean condition code (caused by an over-oiled panel filter) and the car is running great... very predictable yet responsive throttle, it's way faster than stage 1 APR or AMS, I'm loving it
Old 07-06-2005, 07:08 PM
'Nova more S4's Avatar
Default congrats on getting the car up and running again
Will be up around westford this weekend. I'm sure you'll get it all sorted soon.
Old 07-06-2005, 07:11 PM
Dr. Jekyll's Avatar
Default Are you going to the dyno day at Yarrowsport this weekend?
I'd love to get a ride :-)
Old 07-06-2005, 07:44 PM
NoahD's Avatar
no, family is visiting, so I'm busy. Too bad, I'd love to get it on the dyno. Maybe a boston GTG?
Old 07-06-2005, 07:45 PM
NoahD's Avatar
thanks!
Old 07-06-2005, 08:01 PM
New Member
faiz_twinzdaddy's Avatar
Default when u do 3rd gear pulls and start at around 2800 rpm...
...if you floor at it 2800 rpm in 3rd gear how long does it take to hit 1 bar of boost (what rpm....while in 3rd gear??)
TIA
Old 07-06-2005, 08:05 PM
Elder Member
PSmalls::DoggieStyle's Avatar
Default Cool, how about e-mailing/posting logs of 115, 003, 031 seperately.
All 3rd gear WOT pulls from somewhwere in 3k range to redline or close to it. TIA! Congrats on the car getting back together.
Old 07-06-2005, 08:28 PM
Mike2kS4's Avatar
Default Respectable, Log your 02's to see where your fueling is...
AWE kits sometimes run lean A/F's and that costs you power. You can send me your logs if you need some input.
Also, start your FATS run from 3000 or so.
Old 07-06-2005, 10:05 PM
Dr. Jekyll's Avatar
Default If its big enough I'll go. I'm about an hour and a half away from boston
and I value my head lights :-p
Old 07-07-2005, 05:07 AM
NoahD's Avatar
Default I floored it at ~3000, it was at 1 bar by ~3500RPM.
Another time ~3200, hit 1 bar by ~3600.
I'm logging with a pro-diag, so my sampling rate is lower than with a vag-com. This is going to make all of this a bit more approximate.
Quick Reply: AWE Stage 3 with Buehn K03/16 - 4.81 FATS time
