AWE stage 3 new file. Replaced MBC/TCD with N75
Original thread:
https://forums.audiworld.com/s4/msgs/2695678.phtml
It is hard to tell if it is any faster, but one thing I noticed was if I downshifted and WOT I got 20 psi of boost, but if I just WOT in a higher gear from normal driving I only get boost to 15-18. Is this normal?
AudiWorld Expert
any back to back logs, or times? 1/4 mile etc. either from vendor or user... curious to see what the difference translates to.
I actually am having some throttle cut from mine. I;m going to try another N57 valve. When wide open seems to have a problem keeping boost goes 15-20psi up and down. If i go WOT with out downshifting i get lower then normal boost 15-18 and then it will build. I did some logs like that and it is only giving like 80% throttle when i go WOT in a high gear.
I was going to go get the new AWE Stage 3 flash on Monday (not anymore being that 1-2gear are not going in anymore)so I would like to know as well about real world changes.
I think the problem is the boost comes on to fast for the software or n75 to handle so it cuts throttle.
