AWE stage 3 running rich?
#11
either way, Moss told me that the latest AWE file should be just fine at my altitude.
I'm thinking hardware problem, but what?
#13
actually do? I know it shifts the whole fuel curve but what does that actually mean?
#15
I would say to a pressure test and log block 115 as well as 003, 032, and 031. If it turns out ok hardware-wise, then I would look to the fuel mixture map and pull some fuel.
#20
I swapped the 90mm housing for an 85 and ran a couple passes without fuel tweaks. Got limp mode. I had to clear the codes, unplug the ECU to reset it, and pulled 20% with Lemmi. AFR per WBO2 was still only 10.4, but boost was back to normal. I first tried clearing codes and pulling fuel, but the limp mode didn't go away until I reset the ECU.
