Axle Bolt Stuck, any tricks?
I'm trying to do my rear wheel bearings and I cannot remove my drivers side rear axle bolt. It is on there so tight and I do not want to strip it. I tried using a 4 foot extended bar for leverage and I tried using an impact gun with 120 psi and I also tried to hit it with a torch for 10 seconds a few times. It will not budge. Does anyone have any advice for me? Thanks
I had to use a much longer bar--actually the handle of a service jack and borrow a 250 lb. mechanic to pull it down while three of us held the the Audi from rolling forward. Also, using a Snap On heavy duty impact gun will help to loose it before applying the long bar. The bolt is 12.9 pc (property claas) and did not break or strip.
Thanks guys, I ended up having to drive to the Audi mechanic down the road so they could hit it with the acetylene torch. The propane just didn't get hot enough. Now I have other problems though. I can't get the right rear ABS sensor out. It is stuck in the hole and I almost snapped the housing already trying to pry it out.
I have had to destroy mine to get them out. Now I buy new ones to have on hand because all the 10 year old Michigan Audis I work on have been exposed to road salt measured in tons/mile per winter.
Funny you say that. I snapped the drivers side rear sensor trying to get it out today. Is it recommended to disable the ABS system when this happens until I replace it or am I fine driving without one?
B56
09-19-2008 06:21 AM
B56
09-19-2008 04:27 AM
NYC_S
08-11-2008 01:14 PM
realtygary
05-13-2008 09:40 PM
