B4 S4 Long term fuel trims
Old 11-27-2023, 05:34 AM
Jozilla's Avatar
Default B4 S4 Long term fuel trims
I was wondering if anyone here could shed some light on this issue I have been having. I have a 2001.5 s4 b5 rebuilt bel block rebuilt 2.7 heads with 2.8 cams stock intake manifold with 1000cc Bosch ev 14 injectors. The car has been boost test and smoke test for leaks. Idles great no misfires drives great. Its running rich I have replaced both primary 02 sensors new hitachi map sensor. my long-term fuel trims are pegged rich and there’s a nasty split between both bank 1 and bank 2.About 8 percent split.my fuel pressure is on the higher side 59 psi with vacuum. The idle trim sits at 0.8 to 1.0.
Old 12-03-2023, 08:29 PM
AudiAllTheWay's Avatar
What are the actual LTFT numbers? By pegged do you mean +25 and 8% less on which bank?
Fuel pressure is healthy. Are you running stock fuel pump or higher pressure aftermarket pump? Are you running a 4 bar or 5 bar FP regulator?
What kind of BPV’s and have they been tested for leaks?
Old 12-04-2023, 10:29 AM
Jozilla's Avatar
Yes -25 on long term.i have a walbro 450 fuel pump with a 4 bar Bosch fuel pressure regulator.034 diver valves hold vacuum and cleaned. I did notice the fuel pressure is higher 60psi with a vacuum hose connected.
Old 12-04-2023, 10:50 AM
Sounds like not enough intake air aka intake air leak or the fuel system is overpowering aka injectors too big etc.
What tune are you running?
Do you have VCDS or equivalent to do some logging? Log the MAF and requested vs actual boost on a couple 2nd gear pulls, etc.
What is the actual LTFT number for each bank? You mentioned 8% difference.
Are you convinced there is no intake leak? You mentioned smoke test. How about a pressure test to no more than 10PSI?
Old 12-05-2023, 09:06 AM
Jozilla's Avatar
I am running a base tune from ETspec tuning rs6 hybrid turbos 1000cc Bosch EV 14 injectors,Torque Factory intake setup.The car idles great drives fine no misfiresBoost tested up to 15psi smoke tested just rich LTFT.
Old 12-05-2023, 02:53 PM
Bank1 is out of spec for pulling long term fuel but Bank2 is within the acceptable range.
Consider remove Bank1 spark plugs and see if they are all burning the same or not. Maybe one injector is leaking or stuck open.
Old 12-06-2023, 09:09 AM
Jozilla's Avatar
The injectors were brand new but I took them had them clean and serviced with a data sheet showing that they were not bad so I could rule that out.I even swapped injectors from bank 1 to bank 2 same issue.
Old 12-06-2023, 02:54 PM
Swap BxS1’s ?
Old 12-06-2023, 04:40 PM
Jozilla's Avatar
Swap BxS1’s ?
sorry but what is Bx S1s? I have tried moving O2 sensors I installed a new Maf sensor I installed new spark plugs oh the O2s are brand new.
Old 12-07-2023, 07:13 AM
BxS1’s are the front O2’s where x represents either of the two banks.
Sounds like everything is new and you already swapped all critical parts between bank1 and bank2 and you are still getting the same LTFT readings. Is this correct?
Quick Reply: B4 S4 Long term fuel trims
