B5 S4 Misfire
Ok, so I have been having some problems with misfires on cylinders 1 and 4 for quite awhile now. New coil packs have been installed on both of those cylinders as well as new (properly gapped) plugs in all cylinders. I also put new O2 sensors and new EGT sensors in the car and I am still having problems. Only happens when I go WOT but I am running out of ideas on how to fix it..... I had misfires in the past on only one side which turned out to be a bad ICM but now I am completely lost since cylinders 1 and 4 are on opposite sides.....Any help would be appreciated. Thanks
The boot can definitely be the culprit.
It's a lot cheaper to replace the boot then the coil its self.
Most places wont allow you to return electrical parts such as coils either.
We have the boots available ready to ship below.
Click HERE to order or for more information.
![](http://c1552172.cdn.cloudfiles.rackspacecloud.com/2088_x600.jpg)
Let me know if you have any questions.
Pete
Pete
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!![Cool](https://www.audiworld.com/forums/images/smilies/cool.gif)
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
![](https://www.audiworld.com/forums/signaturepics/sigpic191288_1.gif)
I haven't done the seafoam treatment before, I'll give that a shot first. If its still acting up I'll look into doing new boots for the coils. I'm running NGK plugs from ECS. Yes I've had the intake off before.
The reason I asked if you had you intake off before was 1 and 4 are both front cylinders. You might want to check the intake to head mounting bolt to make sure they didn`t come loose. If all else fails you can try the Bosch Platinum Side Fire Plugs (F5DPOR).
http://jhmotorsports.com/shop/catalo...8ef2cb5a0d4032
Ok, didn't really think about that before, I'll check the bolts later this evening. I just picked up some sea foam and put one can into the gas tank. I have another can that I was going to split between the oil pan and vacuum lines. Which vacuum line is best to use for that? The line that runs from the fuel pressure regulator or a different one? Thanks for the advice
