B6 S4 Underbelly
Old 09-04-2003, 07:32 AM
  #31
Driving Excitement!'s Avatar
What does a Stock B5 and Chipped B5 put out on your dyno?
  #32
Elder Member
BiturboBoy_V2.0_S3--'s Avatar
different dynos though...can't compare wit h muc h certainty.
  #33
Elder Member
George @ BostonAudi's Avatar
Default Thats not all I read... sicko.
  #34
SmokinS4™'s Avatar
Default yeah, they are in CT and 93 & 94 are readily available.
but I think Audis numbers are often based on the 98RON that they have as "premium"
On another note, the WRX STi 300HP claims are based on 94, and apparently the guys in CA are getting reflashed at the dealer because of knock issues associated with Craptane.
Old 09-04-2003, 07:33 AM
  #35
SmokinS4™'s Avatar
Looks nice. That looks like a more challenging installation compare the the B5 =)
Old 09-04-2003, 07:39 AM
  #36
AudiWorld Expert
mpwolf's Avatar
Please throw a B5 S4 on the dyno today for comparable numbers.
Old 09-04-2003, 07:40 AM
  #37
RKA
AudiWorld Uber User
RKA's Avatar
Default GIAC X: 250 hp/278 tq, at the wheels.
As Gramps said, it's hard to transport dyno numbers across dynos...even if they are they same type of dyno (which isn't the case here...Speedsports measures at the hub).
  #38
Elder Member
Default are you also popping in that AMD chip?
it would be nice to know if those claims made by them are accurate. believe its chip + milltek = 400 crank HP? i'm a skeptic til i see it.
Old 09-04-2003, 07:41 AM
  #39
Elder Member
Default ahem
lol<ul><li><a href="https://forums.audiworld.com/s4/msgs/1378986.phtml">https://forums.audiworld.com/s4/msgs/1378986.phtml</a</li></ul>
Old 09-04-2003, 07:43 AM
  #40
LCP
AudiWorld Expert
LCP's Avatar
Default That should put the wheels at about 29 lbs. each...
...I had 225/40-18 Rossos on my 26 lb. 18x8 LZ's, and IIRC, the combo was about 49 lbs. I figure 235/40-18 Rossos are about 2 lbs. heavier, so add about 3 lbs. to the weight of the wheels to get 29 lbs.
Quick Reply: B6 S4 Underbelly
