Bad headlight wiring harness/wire?
My passenger side low beam (xenon) will not turn on...but the high-beam works fine. It's not the ballast either because I plugged the headlight into the drivers harness to check it and it fires up perfect. Anybody had this happen before? Which wire is for the low beam in the harness?
TIA
TIA
you can easily trace back the wires from the harness from the housing connection. remove the cover on the housing (one with the plug) and then plug it in, match up the wires.
HIS4
11-25-2006 01:18 PM
$P@ZZ
07-17-2003 08:50 PM
$P@ZZ
07-17-2003 07:21 PM
