Bad Lifters - Major Problem
Old 08-21-2006, 04:35 PM
  #21
AudiWorld Expert
Captain Matt, I be's Avatar
Default the lifters are pretty cheap, gotta pull the cams to replace em though.
there is are restrictors going into the oil galleries in the heads, if one clogged for some reason i suppose it could cause oil starvation within the head.
Old 08-21-2006, 04:37 PM
  #22
AudiWorld Expert
2nd - pull the cams / tensioner and theyre staring right at you.
Old 08-21-2006, 04:38 PM
  #23
AudiWorld Expert
Default valvetrain oil supply is restricted pressure though - strange that higher pressure areas of the
oiling circuit wouldnt suffer more from starvation
Old 08-21-2006, 04:39 PM
  #24
AudiWorld Expert
EF's problem ended up being a cam bearing cap installed backwards from the factory FWIW
Old 08-21-2006, 04:40 PM
  #25
AudiWorld Expert
its a *****NIGHTMARE***** to pull the timing gear off the crank.
Old 08-21-2006, 04:43 PM
  #26
Johnny Bravo's Avatar
Um.. Lifters are expensive. .Its cheaper to buy a rebuilt head.
Old 08-21-2006, 04:45 PM
  #27
Mike2kS4's Avatar
I have a couple heads worth of lifters sitting in my garage.
Old 08-21-2006, 04:48 PM
  #28
AudiWorld Expert
2nd
  #29
Hibiscus Red S4's Avatar
Is this what I have to do to get at the oil pump?
Old 08-21-2006, 04:49 PM
  #30
AudiWorld Expert
$19.95 each at ECS.
Quick Reply: Bad Lifters - Major Problem
