Bad MAP? 16621 Manifold Pressure/Boost Sensor (G31) Signal too low code
16621 Manifold Pressure/Boost Sensor (G31) Signal too low code when MAP is plugged in.
Signal too high when MAP is unplugged.
Can anything other than bad MAP sensor cause this??
Pulled codes with old copy of vag com. Will be trying to log later today.
Currently can't clear the code, have check engine light, only boosting to about 5 lbs (limp mode?) and car hesitates and bucks if given sudden throttle input.
anticsAK
09-04-2015 09:59 PM
Touge.ca
Canadian Discussion
09-02-2015 01:30 AM
