Battery charger question.............
is it ok to connect the other (positive) part of the charger to the metal fire wall right in front of the battery that goes across the engine bay? Is it enough or do i need to connect it somewhere else?
you can ground it to wherever..if it's the dead car, run the ground to the block or body, not the negative terminal of its battery.
red90q
10-25-2006 05:59 PM
