With BBS CH do you change the lugs if so what kind, can you fit 235/40/18 with suspension?
As for tires are concerned, everyone that I know that has anything bigger than a 225/40/18 wheel has started rubbing. My car has CH's with 225/40/18 and if I go extremely hard in the corner, under braking, downhill, with a bump in the turn, I will rub.
My suspension is H&R ultras... set to 25 inches all around.
That should be enough info for you to go on.
If you do want larger tires, be prepared to roll your fenders, at least the fronts as well as cutting your fender liner.
Cheers
Cheers
B5_S4_NYC
Wheels & Tires Discussion
08-28-2003 06:14 PM
Žob
12-10-2001 03:03 PM
Žob
11-06-2001 06:56 PM
Žob
11-06-2001 05:35 PM
