BBS Wheels - Anyone go with BBS RKII Rims? Any Comments?
Guest
Posts: n/a
<center><img src="http://131.107.68.28/a4.org/registry/pictures/KevinKrehbiel.jpg"></center><p>Do a search in the registry; there's one A4 and two S4s that have them or plan to get them. I like 'em, but just make sure you switch to dustless pads; they'd be a bear to clean.
CraigB
CraigB
Guest
Posts: n/a
Alf,
Quarter end must be over if you're back on the forums!
I've finally decided on the RK II's for my S4. I was going with the 18" MM Spiders, but they don't fit the S4. I think I'm going to actually get 17" RK II's, though, because at 18 x 8.5 ET 32 they are just a little wide. I think the 17" setup will be the best price/performance mix in the end (man are 18" tires expensive these days).
I have been calling around here in Toronto to find somebody who would put an RK II on my car to check out, but nobody has them. Just too expensive to keep in stock I guess. Why don't you buy them first and then I can check out your car!
Regards . . . jet
Regards . . . jet
pat33
03-21-2002 04:49 PM
Evan (Vogon)
10-09-2001 11:18 AM
Argeiphontes
12
09-21-2000 11:58 AM
