Bent valve, howto test
Because of the accident, I just heard back from audi that a valve is bent. I towed the car back home. Now I need to figure out what to do next. I am thinking of trying to fix it now, by myself. If I rip off the radiator and radiator support, and try to rotate the engine by hand can I tell if the valves are really bent. When I try and start it all I hear is a click from the starter and thats it. Is there a way to find out before I start ripping the engine apart that they are really bent. Also does anyone have a howto document, like some of the great ones for the timing belts?
if you had a front end colision, you bent at least 12 intakes, sometimes the center intake valve does not get hurt. in a real bad hit, it WILL bend all of them. In a front end hit, the timing belt jumps and your cam timing is WAY off.
the valvetrain is binding(bent valve not sliding in its guide) BTW DO NOT FORCE IT or you will bend more.
