best fats of 3.39 with passenger and on xr with93oct.
#101
The shaft play may not have been so bad during actual running.
Jacob, can you comment?
#102
although there is more room(proven time and time again I know) I just don't want to go there for my daily driver. My car runs 3.3s at 24 psi as does MarkPs as does GatorAls etc... I guess I could make this permanent with a MAP clamp and MBC but choose to let the ECU do what it was coded to.
My point is all it takes is more boost to achieve this on APR, AWE, ASP stuff... timing and fueling are already there. Running more psi/BAR produces this with no other changes/tweaks.
#107
setup. i will let you guys know as soon as i start fooling around.
#108
never had 1 problem with em while they were in. niether has the new owner. i think what verruckt said is correct.
