Best TBB solution....like to avoid $400 worth in pipe or rubber boot...
#21
I have a TBB idea....
It's a Home Depot mod.
Instead of a Y-shaped TBB why not have a hose come straight out (think rubber plumbing adapter or shortened IC hose.) Then pick up a 2" diameter PVC "T" pipe that has the divider in the middle. The bi-pipes can be fitted from PVC or something else and either be cemented into the T or use rubber adapters. The T can have 45-degree adapters cemented to it that direct down towards the ICs.
... you get the idea. It could just work and be do-able for under $20.
The reason the TBBs stretch and break is because they're handling stress in multiple directions. It's kind of silly to engineer a part with those kinds of stresses on it. So why don't we alter the type of parts used?
#25
SIR, please put down the AW, paranoia has set in full force...
...Piggie Clamps avoid just that, they are rolled edges that prevent/ minimize the clamp from cutting into the TBB. So you can tighten the TBB tighter. :-)
#26
This is gonna be the standard in a couple weeks when released...
<center><img src="http://www.turbohoses.com/AudiS4.jpg"></center><p>
Even Hoppen will be discontinuing their $400 MTM TBB for this thing b/c it holds up better. I heard price should be around $200.00<ul><li><a href="http://www.turbohoses.com/index.html">G-Werke TBB</a></li></ul>
