Best way to remove caked on brake dust?
Old 12-23-2003, 01:10 PM
New Member
allroadbarks's Avatar
Default Best way to remove caked on brake dust?
What is the best way to remove caked on brake dust from stock rims? Are there any products that are recomended or processes?
Thanks.
Old 12-23-2003, 01:12 PM
AntiSocial's Avatar
Try windex
Old 12-23-2003, 01:14 PM
Andy Hedin's Avatar
Default P21S gel wheel cleaner...
...or if they're really neglected, Kaboom. Search the Detailing Forum archives for Kaboom and you'll see some pretty amazing before and after wheel shots.
P21S Gel wheel cleaner info:
<i>P21S® Gel Wheel Cleaner - for wheels that tend to soil heavily due to higher braking speeds, softer brake pads or infrequent cleaning. Spray on, allow to stand up to two hours, touch stubborn spots with a sponge and rinse off with a sharp stream of water. Gel composition clings to vertical surfaces to provide increased cleaning effect.</i><ul><li><a href="http://www.autogeek.net/p21s.html">P21S Wheel Cleaning Products at Autogeek.net</a></li></ul>
Old 12-23-2003, 01:15 PM
AudiWorld Expert
Mark.core's Avatar
Default Formula 409 is pretty amazing at doing that... Your finger is the best brush.. Go figure.
Or should I say, Go finger .. HaH ah Ha .. Okay sorry. 409 has always impressed me .. Just eats it up.
Junior Member
DrSmile's Avatar
WD40 - Seriously!
Junior Member
Bryan Slowgaro's Avatar
Goof-off.
Old 12-23-2003, 01:33 PM
Billaeon::FATS (2.0)'s Avatar
Second that
Old 12-23-2003, 01:46 PM
frank's Avatar
2nd that, gel not spray
Old 12-23-2003, 01:50 PM
RKA
AudiWorld Uber User
RKA's Avatar
Default Stock rims...give it a shot of Kaboom bathroom cleaner...let it soak for 5 minutes, then wash and
rinse. Little black specs (repolymerized brake dust) can be handled with WD40 (so I hear).
I wouldn't recommend Kaboom for fancy aftermarket wheels. Finish and
materials vary too much to make the recommendation without reservation. OEM wheels tend
to hold up pretty well to Kaboom...those I'll confess...I'll only use the Kaboom when
absolutely necessary. As soon as I get the wheels spotless again, I throw a few layers of
wax on them...from there on out, simple car wash soap does the job.
Old 12-23-2003, 01:53 PM
Elder Member
S4mig@PEB tuning's Avatar
Simple Green
Quick Reply: Best way to remove caked on brake dust?
