Bleeding brakes using the VAG tool to cycle the ABS pump
I'm writing this solely for the sake of the archives, because I couldn't find the answer in the S4 forum when I searched for it.
Search terms:
ABS
cycle
VAG
brake
bleed
tool
Open the VAG program, select the ABS module. Select "Function 04." If it's not already in Basic Settings, switch to Basic Settings. Run block 002. As soon as you do it, the fluid will flow much faster for about 5-10 seconds.
Search terms:
ABS
cycle
VAG
brake
bleed
tool
ex-quattro PETE
02-12-2004 10:15 AM
NickS
13
01-21-2002 10:36 AM
