boost lag from my k03/16 clipped. what gives?
Old 09-10-2005, 07:15 PM
  #11
Mike2kS4's Avatar
Default Well, if you can't get any more than 13# peak when you adjust MBC totally clockwise...
You should first pressure test, and if that comes up blank adjust the WG's.
I posted on how to do this yesterday, FYI.
Old 09-10-2005, 07:23 PM
  #12
Junior Member
myfootsmells's Avatar
Default i pressure tested today no more boost leak. what happens is i spike to 20 psi and around 5000 or so
RPM it drops down to 13
Old 09-10-2005, 07:32 PM
  #13
Mike2kS4's Avatar
Default That sounds precisely like Turbine Inlet Pressure opening the WG's...
Adjust them, carefully. Turn your boost down and relog.
Old 09-10-2005, 07:40 PM
  #14
Junior Member
Default how many initial turns do u think? 2?
i'm turning the nut towards the front of the car right?
Old 09-10-2005, 07:41 PM
  #15
AUDIS4BI:Vintage's Avatar
nice meeting you today btw.
Old 09-10-2005, 07:52 PM
  #16
New Member
Keyboard_Tuna's Avatar
Default Turning towards the front of the car?!
The Tuna laughs at you. Rotating objects don't work like that. Try clockwise or counterclockwise.
  #17
Elder Member
PSmalls::DoggieStyle's Avatar
I agree 100% with MM's thinking. It sounds like a wastegate adjustment is in order.
Old 09-10-2005, 07:59 PM
  #18
Elder Member
w0000!
Old 09-10-2005, 08:05 PM
  #19
Junior Member
yes turning towards the car, those who have done it probably knows what i mean
Old 09-10-2005, 08:19 PM
  #20
Mike2kS4's Avatar
Default I obviously haven't done it, because I have no clue as to what you mean.
I'd have to side with the fish on that one.
Clockwise increases boost, counterclockwise decreases. Usually 1/4 turn is 1psi.
zacharyhinman999
09-26-2017 10:24 AM
biturbopassat
02-03-2010 04:55 AM
Nogaro Stg3
06-22-2006 04:42 PM
PKBlu::E30 Hunt
14
12-22-2005 09:23 AM
QGMika
Performance and Tuning
07-22-2003 06:11 PM
Quick Reply: boost lag from my k03/16 clipped. what gives?
